P3Dv4 compatible aircraft and scenery
Everything P3D from v1 to v5.
I have found the most planes from FSX will work in P3Dv4 provided that they are not port overs from FS2004 (FS9)
The model needs to be a FSX native model SP2 Compatible before you consider testing it in P3Dv4. Also if it worked in P3dV3 it should work in v4.
As of V4.3 the Captian Sim C130 has been added as a default aircraft. Also note the v4.4 is expected to be out by the end of 2018.
So far I have not found any FSX scenery that is not compatible in V4.
