X-Plan 11.50 has arrived.
X-Plane 11.50 has been released.
If you experience a crash to desktop right after the Plane loads, As I have. I found that XPUIPC is the culprit. A workaround has been posted to insure the correct IP address in the Config ini file is correct Even if you do not network IE everything runs on one machine. Also, check and see if you have the latest XPUIPC version, which should 2.0.5.9 or higher.
X-Plane 12, MSFS 2020, VATSIM-P1, Pilot2ATC, Air Hauler 2(Westwind Air Hauler 2 VA owner), A Pilots Life, Active Sky XP, TDFI PACX, Real World Private Pilot.
