Hi all,
Looking through the X-Plane hangar, it seems there is a likely chance that the X-Plane 10 livery you're seeing in the hangar could be compatible with X-Plane 11.
These aircraft are:
- JAR Design Airbus A320
- JAR Design Airbus A330
- FlightFactor (AKA VMAX) Boeing 777-200LR and 777F
- VMAX Boeing 787-8
- JRollon CRJ200
- FlyJSim Q400
- JRollon BAe Jestream 32 (?)
As in the case with FSX paints working in P3D, be sure to check them out if you're flying one of the aircraft above, as chances are those paints may work with X-Plane 11. This weekend I will go through and make updates as to which ones are compatible with X-Plane 11 and which ones that say "Houston, we may have a problem here..."
Regardless there are more paints coming for X-Plane soon. When there is a drought for many years, there is a chance it may rain soon.
X-Plane 10 liveries may work with X-Plane 11...
Alex Lu, WWA3293
KLAX Hub
KLAX Hub
Re: X-Plane 10 liveries may work with X-Plane 11...
Following up here. After cross-checking our X-Plane 10 liveries and directories with those made in X-Plane 11 (by downloading and looking at the file directories and textures), I have updated the following aircraft to show compatibility with XP11. They are not tested as I don't own those aircraft, but they should work with XP11.
- JARDesigns Airbus A320neo (changed from A320 because the textures say it is the NEO version, not the regular A320 version)
- JARDesigns Airbus A330
- FlyJSim 727-100, -200, -200Adv, -200F (all versions, thanks to WWA1813 on a forum post back in 2020)
- IXEG Boeing 737-300
- FlightFactor/VMAX 777-200LR
- FlightFactor/VMAX 777F
- FlyJSim Q400 LEGACY (not the newer Q4XP for XP11 - they have two completely different textures)
- JRollion CRJ200
- JRollion BAe Jetstream 32
If I'm wrong here, please contact us here and I'll correct the list accordingly. It just takes a few mouse clicks.
- JRollion CRJ200
Alex Lu, WWA3293
KLAX Hub
KLAX Hub
