P3D V4 Update
P3D V4 Update
If you plan on updating you P3Dv4.x to V4.4 be sure to backup you simobjects/airplanes folder so you can reload the default aircraft that have been removed.
WWA3370 Jason Weaver
Re: P3D V4 Update
Yeah i guess Textron ended its support with LM. LM added the AC11 though. Never used the Beechcraft anyway or i have Carenado for that.wwa659 wrote:If you plan on updating you P3Dv4.x to V4.4 be sure to backup you simobjects/airplanes folder so you can reload the default aircraft that have been removed.
