Page 1 of 1
XPilot tutorial
Posted: Thu Oct 24, 2019 12:49 pm
by Sean McConnell WWA659
I found this tutorial on how to install and set up XPilot
https://www.youtube.com/watch?reload=9& ... 7K_h4ZlNFo
Re: XPilot tutorial
Posted: Wed Oct 30, 2019 10:43 pm
by WWA1813
Thanks. I'll take a look at this. I used to fly vatsim on FSX. Haven't tried it on XPlane yet.
Re: XPilot tutorial
Posted: Thu Oct 31, 2019 2:32 pm
by WWA2660
I switched from XSquawkbox to XPilot and the only thing that bit me was to ensure that you do have the com selected in the audio panel in the aircraft or you'll not see the R lightup for the frequency in XPilot even though T will be lit up. So I added enabling the com on the audio panel as part of my cold and dark procedures.
Re: XPilot tutorial
Posted: Mon Sep 06, 2021 3:23 pm
by WWA1103
I had been using Swift but I thought I would give the xPilot client a try.
The install was infinitely easier with xPilot than with Swift, much more user friendly.
But it was more picky about my sim’s framerates and booted me any time the fps dropped to 19, which it was doing a lot in heavy clouds. I turned off weather to Cavok and then had no issues. So if your fps is solid above 30 even in clouds you will be fine. If not do some graphics tweaking or lose the clouds.
Re: XPilot tutorial
Posted: Sun Sep 12, 2021 1:43 pm
by WWA2660
For those low frame rates in X-Plane 11 make sure you are running with Vulkan turned on in the graphics settings. That jumped my frame rate by 10-15 fps and avoided this issue.
Re: XPilot tutorial
Posted: Mon Sep 13, 2021 8:50 am
by WWA1103
Yes I have an old graphics card and need to update, but getting a newer card is really difficult at the moment.
Re: XPilot tutorial
Posted: Mon Sep 13, 2021 5:57 pm
by BobSturm
WWA1103 wrote: ↑Mon Sep 13, 2021 8:50 am ... but getting a newer card is really difficult at the moment.
And EXPENSIVE when you can find them!
