X-Plan 11.50 has arrived.
Posted: Mon Sep 14, 2020 12:03 am
X-Plane 11.50 has been released.
If you experience a crash to desktop right after the Plane loads, As I have. I found that XPUIPC is the culprit. A workaround has been posted to insure the correct IP address in the Config ini file is correct Even if you do not network IE everything runs on one machine. Also, check and see if you have the latest XPUIPC version, which should 2.0.5.9 or higher.
