Heading/OBS adjustment bug
Posted: Sun Nov 29, 2020 8:57 pm
				if you are experiencing an issue where you can only adjust the heading Bug, OBS, or even the trim wheel in 10 unit steps with your yoke/joystick it is NOT your device that is at fault or causing the problem.
This gentleman explains and demonstrates the issue very well in several different ways. I knew it was not an exclusive honeycomb yoke problem, which is what I do have but I did not understand what was going on. And after watching this video I believe he is correct. because He also demonstrates the same problem when buttons are held down as well as toggle switches. here is the video https://www.youtube.com/watch?v=dc2dsZY ... sLoiehYTAs
