Page 1 of 1
				MisterX Library updated
				Posted: Sat Apr 03, 2021 3:19 pm
				by Sean McConnell WWA659
				MisterX updated its object library to version 2.0 as of 3 April 2021. this library is popular amongst scenery designers so you should update to the latest copy
here is a temporary link
https://drive.google.com/file/d/1MPRZ70 ... Mc1Il/view after this link goes down you can get it from the X-Plane.org forums.
				Re: MisterX Library updated
				Posted: Sat Apr 03, 2021 3:32 pm
				by WWA2379
				Hi Sean,
You should add the link to xplane.org to our links library if its not there already
				Posted: Sat Apr 03, 2021 6:24 pm
				by BobSturm
				Mister-X Library is a required download for all of my X-Plane WestWind scenery.
				Posted: Sun Apr 11, 2021 8:15 pm
				by BobSturm
				I Just discovered that MisterX_Library 2.0 is only a "Add On" to previous versions, not a complete library. I have been using MisterX_Library 1.61 for my sceneries. Any future scenery will need BOTH 1.61 and 2.0.  I will specify this in any future "readme" files that I include. I will also need to modify the description on the scenery download page for the existing scenery.
				Posted: Sun Apr 11, 2021 10:05 pm
				Thanks, Bob, I need to go back and reinstall 1.61
Edit: It seems all the links have been updated to 2.01. I can not find a link to 1.61
				Posted: Mon Apr 12, 2021 4:28 pm
				by BobSturm
				I can't find any link either. He didn't even include instructions to extract it over top of previous versions, which is what I did. I'm trying to find a way to contact the author to explain the situation he created. I'll see what I can work out. [EDIT] I removed the MisterX library from my system, then I loaded each of the scenery  files that I have completed. All of them gave a warning about the missing library. Chicago was the only one that it had a major affect on, so I revised that airport and am waiting for a response from IT regarding the upload issue for that file. Since I didn't use very many MisterX objects in the other airports, I will revise those files, eliminating the MisterX objects. I will then upload the revisions to the web.
