X-Plane 12 Questions
Posted: Thu Aug 11, 2022 10:06 am
by WWA3293
The arrival of X-Plane 12 is just a matter of time. When asked by the audience, the founder of X-Plane, Austin, said that X-Plane 12's release date is about 30 days at Oshkosh (that was July 29).
Just curious, how many of our pilots (both current X-Plane pilots and others) are going to get X-Plane 12 on day 1?
And if you are, would you be willing to fly the default Airbus A330, Citation X, and/or Cirrus SR22, or would you be sticking with the aircraft you have already for XP11 assuming assuming it also works with XP12 (FlightFactor, ToLiss, hopefully the Zibo/LU 737s, FlyJSim, etc.)?
Re: X-Plane 12 Questions
Posted: Thu Aug 11, 2022 12:37 pm
Yes, I plan on getting X-Plane 12 as soon as it becomes available.
Yes and yes I will be looking at the new default aircraft and also bring in what I can from X-Plane 11.
Posted: Thu Aug 11, 2022 4:01 pm
I will get X-Plane 12 right away if it isn't too costly. With inflation running rampant, I'm struggling to keep gas in the car in order to work. I will try out the default aircraft but don't expect they will be of the same quality as my payware.
Posted: Sat Aug 20, 2022 12:37 pm
by John Oddo WW2293
I think I will wait till they shake out all the bugs
Posted: Fri Aug 26, 2022 9:34 pm
by WWA3293
I wonder if X-Plane 12 has a demo version like all the previous versions. Like John I am planning on holding off getting X-Plane 12, but if there's a demo version there's a chance I may get a start on painting the new default aircraft.
Posted: Fri Aug 26, 2022 9:41 pm
It will probably be after the early access or public beta before the demo is released.
Hint the Early Access or Public Beta is on final according to rumors.
Posted: Mon Aug 29, 2022 4:46 pm
by WWA2660
I'll definitely be getting it. I plan to try the early beta release but I will also keep my X-Plane 11 around until 12 is stable enough.
Posted: Tue Aug 30, 2022 7:22 pm
by WWA3293
wwa659 wrote: ↑Fri Aug 26, 2022 9:41 pm It will probably be after the early access or public beta before the demo is released.
Back in 2016 when Laminar had X-Plane 11 on public beta/early access they had a demo version for that, before actual release. So I wonder if they're going to do it again.
Also, speaking of X-Plane 12... https://twitter.com/XPlaneOfficial/stat ... 8953882626
