MAJOR MSFS PMDG 737 LIVERY UPDATE 2.0
Everything related to Microsoft Flight Simulator.
WWA3293
Post by WWA3293 » Sat Apr 08, 2023 5:53 am
Given the magnitude of LIVERY VERSION 2.0 for all of the MSFS PMDG 737 variants, I will outline how to properly update your liveries to prevent problems such as the new liveries not showing up. All of this is mentioned in the readme files.
PMDG 737-600
Minor font color changes to “WestWind” font at front of aircraft. Delete old livery before installing!
PMDG 737-700, BDSF, and BBJ
Liveries are NOW SPLIT INTO THREE SEPARATE DOWNLOADS! The folder structure is refactored to reduce disk space (from 300MB for all three variants to about 40-50 MB for each variant). Delete “pmdg-737-westwind” (which contains all three variants) before installing! If you don’t do that your liveries will not show up in-sim.
The new folder names are:
- pmdg-737-westwind (now only includes the pax variant)
- pmdg-737bbj-westwind (BBJ variant)
- pmdg-737bdsf-WWCL (BDSF freighter variant)
PMDG 737-800, BCF/BDSF, and BBJ2
Folder structure is refactored to reduce disk space, from about 80-200MB per variant to about 40-96MB per variant. Delete all previous versions before installing! If you don’t do that your liveries will not show up in-sim.
PMDG 737-900 and -900ER
PMDG 737 ini configuration files
Now comes standard with every MSFS PMDG 737 download. If you want the master download and PDF guide, it is now only located at Boeing 737-700 listing for easy maintenance.
Reposted from Aircraft Department Forum for easy access
Alex Lu, WWA3293
KLAX Hub
