New Reasons for MSFS Freezing
Posted: Sun Feb 18, 2024 2:13 pm
by WWA2244
MSFS froze at around FL200 when flying out of KORD. After several tries the same thing happened. Unable to complete a flight. Did a flight out of another airport and there was no problem.
Yesterday, I was flying out of KBUR and had the same freezing problem at FL200. After several tries, same problem.
Searched for a fix online and read several articles that said it was a problem with the mouse. Said to disconnect and reconnect it and to slow the pointer speed. Also, it said MSFS needed a patch to fix the problem. I did the supposed fixes and will try flying out of KBUR today. If the problem continues, I will try flying out of a different airport.
Any comments, insights, advice?
Re: New Reasons for MSFS Freezing
Posted: Mon Feb 19, 2024 2:55 pm
by WWA2244
I uninstalled flybywire and during the reinstall, it advised a cockpit texture improvement could cause problems. Deleted that, finished the install, and MSFS worked great. I think that some downloads can cause problems when MSFS or the flybywire A320 Neo is updated.
Posted: Mon Feb 19, 2024 7:43 pm
Thanks for that update, X-Plane is my main sim so when I go to fly MSFS 2020 I usually need updates to the sim and other downloaded add-ons.
