VATSIM has made the determination that each of these interface clients for VATSIM are being retired.
Any person who is running FSInn or SquawkBox 3 (SB3) will need to change clients to log into VATSIM going forward.
For those running FS9, it appears that SWIFT will be the only choice available for you. For FSX users, vPilot should be downloaded and installed.
vPilot, once installed, should be run in ADMIN mode, and configured to run as an administrator
to ensure that everything works and runs correctly.
FSInn and SquawkBox3 Issues VATSIM
Re: FSInn and SquawkBox3 Issues VATSIM
OK, So I will make it clear by posting this now
HOW ABOUT A DETAILED FAQ on exactly how to install, and make operational the new voice codec, and how to set it up in step by step detail for FS9/Swift ( as it is the only game in town) and FSX, P3D etc for those pilots.
VATSIM has done nothing to detail how to do it or even how to set things up.
16% of pilots fly FS9,, a detailed step by step FAQ is desperately needed
Also too is anyone working on detailed Westwind information to be used in SWIFT so Westwind Aircraft show up properly?
You need to have little patients here, I am trying to come up with a guide to use Swift, But swift is still an experimental alpha state and things I wrote last night is already null and void.CaptD3601 wrote: ↑Wed Oct 23, 2019 6:05 pm OK, So I will make it clear by posting this now
