MisterX updated its object library to version 2.0 as of 3 April 2021. this library is popular amongst scenery designers so you should update to the latest copy
here is a temporary link https://drive.google.com/file/d/1MPRZ70 ... Mc1Il/view after this link goes down you can get it from the X-Plane.org forums.
							MisterX Library updated
Re: MisterX Library updated
Hi Sean,
You should add the link to xplane.org to our links library if its not there already
George Forster WWA2379
Westwind VA Positions
Chief Information Officer
Flight Sim used - MSFS2020
Addons - FSHud, FlyByWire traffic
Mister-X Library is a required download for all of my X-Plane WestWind scenery.
Bob Sturm -- Sr. Command Capt. +22
I Just discovered that MisterX_Library 2.0 is only a "Add On" to previous versions, not a complete library. I have been using MisterX_Library 1.61 for my sceneries. Any future scenery will need BOTH 1.61 and 2.0.  I will specify this in any future "readme" files that I include. I will also need to modify the description on the scenery download page for the existing scenery.
Thanks, Bob, I need to go back and reinstall 1.61
Edit: It seems all the links have been updated to 2.01. I can not find a link to 1.61
I can't find any link either. He didn't even include instructions to extract it over top of previous versions, which is what I did. I'm trying to find a way to contact the author to explain the situation he created. I'll see what I can work out. [EDIT] I removed the MisterX library from my system, then I loaded each of the scenery  files that I have completed. All of them gave a warning about the missing library. Chicago was the only one that it had a major affect on, so I revised that airport and am waiting for a response from IT regarding the upload issue for that file. Since I didn't use very many MisterX objects in the other airports, I will revise those files, eliminating the MisterX objects. I will then upload the revisions to the web.
